Hi all,
Just completed a burn pot & burn ring replacement on my 422. Everything went well thanks to these forums and all the good info here.
I was missing one gasket at the top of the burn chamber where I had to reuse the old gasket.
It started up fine, burned nicely. A few days later, when the burner kicks up into high heat, there are bright flashes visible in the chamber window. Every 3-6 seconds a very bright flash will light up the window. There's no noise associated with it. When it's not flashing the flame looks OK, maybe a bit yellow. At a lower burn the flame is a nice crisp blue around a glowing red burn ring. Searched the forums, couldn't find similar symptoms.
Thanks!
Thanks!
