material for making a burner mat / cloth for Monitor 40
  • moses26
    • Nov 2013
    • 6
    Hello,
    Does anybody know where to get cloth material to fabricate my own burner cloth mat instead of buying a pre-cut one from Toyotomi?
    Please let me know.
    Thanks !!
    Moses
    material
    check mcmaster-carr industrial supply [www dot mcmaster dot com]
    look for ceramic fiber sheet goods.
    • moses26
      • Nov 2013
      • 6
      Thanks for the info HayZee,
      There seems to be some products but I'm not sure what options are viable:
      www dot mcmaster dot com/#ceramic-sheets/=qjc49u
      would you please take a look at the website and let me know if you have any specific suggestions?
      maybe the "Very High Temperature Machinable High-Alumina Ceramic"? doesn't it need to look like a mesh?
      Moses
      • FordMan59
        • Dec 2011
        • 355
        Burner Mat Material
        Two years ago when I replaced the burn mat in my Monitor 422 I used silica cloth for the new burn mat. McMaster-Carr product number 8799K3. I also used Rutland 77 stove cement for gluing it to the bottom of the pot.
        • moses26
          • Nov 2013
          • 6
          Originally posted by FordMan59
          Two years ago when I replaced the burn mat in my Monitor 422 I used silica cloth for the new burn mat. Mc Master-Carr product number 8799K3. I also used Rutland 77 stove cement for gluing it to the bottom of the pot.
          You rock !
          Excellent, thank you very much.
          Do you have any recommendations for the material to make the round large gaskets for the heat chamber?
          Moses
          • FordMan59
            • Dec 2011
            • 355
            Gasket Material
            Originally posted by moses26
            You rock !
            Do you have any recommendations for the material to make the round large gaskets for the heat chamber? Moses
            I used McMaster-Carr product number 9323K21. This material is thinner than the original Monitor gasket material and may need to be doubled on some applications, but it's a much stronger material than the original Monitor gaskets.
            • moses26
              • Nov 2013
              • 6
              Ok ! thank you very much.
              Moses
