Monitor fuel tank purge
  • woodauger
    • May 2014
    • 37
    thanks to all who have posted such a volume of information on this site. I am hoping to use a pair of Monitor heaters in place of a forced air furnace next winter, an intended to use the existing fuel oil tank as it is empty, in basement already, and in new shape. I saw advice on the Toyostove website to have the tank purged if it had been used previously as mine has. Does this pertain to the Monitor also? Would flushing with a few gallons of K1 be sufficient? Thanks in advance
    • 758
    tank in basement
    If you do not know what type of fuel was used it would be a good idea to flush the tank with #1 fuel or K1 or what ever they call it in your area. You will need a filter on the tank after the shut off valve. Since the tank is in the basement you may need a fuel lifter pump. They cost around $400. This will get the fuel up to your first or second floors so it can be used by your Monitor. You can use the lifter to run two heaters with no trouble. If one is on the second floor and one is on the first you will need a pressure reducer for the first floor unit. The lifter should be placed a little higher than the top of the heater which will give you enough gravity feed to run it.
    • woodauger
      • May 2014
      • 37
      Monitor fuel tank
      Thanks much, Tom - I have been using some of your previous posts as I considered this change for some time now. As the 422 and 30 are both used, I'll likely be begging for advice again. Gary
      • Bryand
        • Dec 2011
        • 99
        If you are going to use a Monitor 30 you will be begging for advice and parts as there are no parts left for them.
        • woodauger
          • May 2014
          • 37
          Monitor 30
          This was one of the subjects I was lucky to read on this forum. The 30 was a freebie, and I have a backup Monitor for when it's worn out.
