Hello
I have been using a monitor heater for over 15 years without it ever being serviced.
Yesterday after it locked out, i restarted the heater and noticed a very high yellow flame, and after several minutes the unit shut down(probably over-temp?)
I started to dismantle the heater and have gotten to the point where i have removed the chamber cap(6321) and also removed the combustion ring (6356). The combustion ring is deformed in one area , and part of the burner cloth (6363) missing. After removing some carbon build up on the burner (6401) everything seems to be ok.
One key note is i did find a piece of carbon bridging from the burner to the flame detector plug.
I have thoroughly vacuumed and removed all debris from pot area and even placed a vacuum hose up into the bottom of the burner
I planned to just replace the ring 6356 and the cloth 6363, without complete dismantling the system.
I would like opinions is this is enough to get my monitor back up and running properly or could something else be a miss that caused the large yellow flame?
Also, i have never had the fuel chamber apart(screen clean yes), is it possible junk got into the needle valve and just flooded my burner?
Thank you in advanced
P.S. would have uploaded some pics but kept getting errors
