Monitor GF500 Burner light blinking
  • zman
    • Mar 2015
    Hello forum again,
    My Propane Monitor GF500 is acting up again. The burner light bars are blinking. I turned it off and turned it back on, it worked for a few days. Now it just blinks and it won't ignite. Please help me. I am in the middle of Winter in Maine again. Thanks in advance
    • 755
    Do you see a flashing in the window when the stove tries to start? If not the igniter is not working.
      check the air flow hoses. make sure they are not cracked where they go over the nipples on the air proving switch. the gas fired shouldn't give you flamerod errors because propane doesn't create carbon. check the exhausr tube, maybe there is an ice build up in the tube,
