GF500 question
  • msearcher
    • Mar 2011
    • 125
    GF500 question
    Trying to get a GF500 to run, it's LP and won't fire.
    the ignitor makes noise and can see it arc on the outside ( can't believe that is a good sign ).
    trying to run this off a LP tank - any help would be appreciated.
    Replaced bearings in combustion and fan motors and the o-ring in the damper prior to try running heater.
    • 755
    If you hear or see the igniter then it is good. Have you set the stove up for LP gas? Since you re worked the blower, did you get all the wires back in the right place. The gas stove has a similar set up to the oil heater when it comes to over heat and no blower. If those wires are not right you will get no fuel.
