Hello thank you for the useful information in the previous posts. I have owned a 441 for 10 years now and seen it through all stages of repair. Now I am at a loss. At the end of a normal heating cycle the fuel pump will be called to come on and kerosene is pumped in, at this point when the next ignition cycle starts, there is a good poof and the room smells like kerosene smoke, the poof of smoke also happens on shut down about every other time. Just recently the economy plus stopped working in this manner, it would heat the room to 8 degrees over setpoint and when the heater was called to go into low mode, for the additional 4 degrees, the heater would shutdown and all panel lights will start blinking. Any insight to this problem would be much appreciated.
Thanks Brian
Thanks Brian
