Thanks that was very helpful, when the burner lights kick in to half way the voltage between blue and yellow goes to a solid 108V DC.  So that means the power should be getting at least to the TAISAN, correct?
So if the power there is 108V DC and the pump is 600 ohm but there is no noise from the pump can it be that the whole thing is gummed up with gunk inside the pump filter/etc.? This thing sat for a long time, I wonder if it should just all be cleaned out?
I can read a schematic so if you have something for the M22 or M41 which is similar I would appreciate a link/pointer.
Thanks!
Thanks!
