Monitor 441 heater shuts down
  • Downaski
    replied
    Yes! Thank you so much for checking in, I really appreciate it!
    replied
    Downaski​, did you get to the bottom of your issue?
  • Downaski
    replied
    Got it! Thank you so much, Tom. I will let you know if I need any further assistance. 😊
    replied
    By all means change the filter. It should be changed every year. When you change the filter there is a chance the filter will get air locked and not allow fuel to get to the heater. If this happens take the copper line completely off the filter and put a can under the filter. Turn the fuel on and let it run out for a bit. Close the valve and install the copper line. This will get all the air out and allow the fuel to get to the stove.
  • Downaski
    replied
    The flame sometimes dips below the burner ring, and there’s an occasional thumping sound. The flame also reduces in size at certain points. I am not sure about the last time the unit was serviced but the fuel level seems more than enough which for my understanding points towards the unit is struggling to get enough fuel. Would you recommend just changing the fuel filter or should it be fully serviced?
    replied
    You have to watch the flame during the whole time the cycle is on. Is the flame above the burner ring? Do you hear a thumping and see the flame reduce its size.
    You are correct, this could be a fuel issue. If you have not changed your filter in a long time, it could be dirty. Your fuel level could be low.
    Now the big one is, when was the last time the stove was serviced? Serviced being a new burner mat and a new burner ring, fan in the back cleaned??
  • Downaski
    replied
    Hi TT and Tom!
    The flame is on. Is this a fuel filter issue? As it seems like the heater is not getting a consistent fuel supply.
    replied
    Can you see a flame in the window? Do you hear a thumping noise when the status lights are on?
  • TinyTool
    replied
    Hi!
    Fuel quality is a common culprit in heater problems. Over time, fuel can degrade or become contaminated with water or debris. This can cause the heater to shut down as a safety measure. If your fuel has been sitting for a while, or if you suspect it might be contaminated, it's worth draining the tank and refilling it with fresh, clean fuel. The fuel filter is another key component to check. As it does its job of catching impurities, it can become clogged, restricting fuel flow to the heater. This can cause the heater to run for a short time before shutting down due to insufficient fuel supply. Most manufacturers recommend changing the fuel filter annually or every 500-1000 hours of operation. If the fuel pump is malfunctioning, it might not be delivering enough fuel to keep the heater running. You might hear unusual noises or notice the heater struggling before it shuts off. Testing the fuel pump usually requires specialized equipment, so this is often a job for a professional.
    A blocked air intake can cause the heater to shut down as a safety precaution. Check the intake for any obstructions like debris, spider webs, or even small animals that might have nested there. Cleaning the intake regularly can prevent this issue. Similarly, problems with the exhaust system can cause shutdowns. A blocked exhaust pipe can lead to a buildup of harmful gases, triggering a safety shutdown. Inspect the exhaust pipe for any visible blockages or damage.
    The flame sensor is a critical safety component. If it gets dirty or fails, it might not detect the flame properly, causing the heater to shut down. Cleaning the flame sensor with fine-grit sandpaper can often resolve this issue, but be careful as it's a delicate component. Issues with the control board can be tricky to diagnose without specialized equipment. The control board manages all the heater's functions, and if it's misreading signals from other components, it might shut down the heater unnecessarily.
    Lastly, check your thermostat settings. If it's set too low or malfunctioning, it might signal the heater to shut off prematurely. Ensure it's set to an appropriate temperature and that its batteries (if applicable) are fresh.
    Remember, while some of these checks can be done by a handy homeowner, others require professional expertise. If you're unsure about any step, it's always safer to consult with a certified technician.
    Hope this helps! If you need any further assistance, feel free to ask!​
  • Downaski
    started a topic Monitor 441 heater shuts down
    Hi! Monitor 441 heater shuts down after a few minutes of operation, even though the fuel tank is full.
    Can someone help with this? Thank you!
