1103 Lifter Pump
  • NalaBear
    • Dec 2010
    1103 Lifter Pump
    I've just installed a mildly used pump that has been stored for a few years to use with a 441. Plugged in, flipped power switch, nothing happens. Replaced 1A fuse, nothing happens. Checked and power is getting to on/off switch but does not get from circuit board to pump. Is there a way to bypass the circuit board? If not, is the board replaceable and if so, suggestions for parts dealers in Idaho? Many thanks in advance!
    just a suggestion buy a toyo lifter pump.
    • NalaBear
      • Dec 2010
      Is the monitor pump junk, as in not worth the money to repair? I presume you mean a new toyo is better than new monitor lifter pump? Do you know what model pump is compatible with the 441?
        there's only one pump available for all the toyo heaters.
        • jimary
          • Dec 2014
          The Monitor 1103 Lifter Pump must be primed with fuel oil before it will operate.
          • jimary
            • Dec 2014
            This pump must be primed with fuel oil before it will operate.
            • msearcher
              • Mar 2011
              • 125
              I have found that I needed to prime with more fuel that the manual indicated before it would work.
              • msearcher
                • Mar 2011
                • 125
                I believe I have an 1103 manual if you can't find one online.
