service new Laser 730, 560
    • 758
    Servicing a newer style Laser heater, you will notice the front panel has a ribbon strip connecting the indicator panel to the main circuit board. The Operations Panel can be removed by pressing the two tabs at the top of inside of the panel and remove the panel from the front cover. The panel can now be laid down and operated. To put back on, Slide the panel into the front cover and place the bottom into front cover. You can then click the top tabs back in and it will be set.
    • 758
    The next surprise you will run into when servicing a L560 or L730 is that, if the installer did not put a fuel shut off valve inside the house, next to the stove, you can not shut off the fuel at the heater. Being able to control the fuel flow right at the heater is really nice when trouble shooting fuel flow. The new stoves do not have a fire safety valve with a handle. Also be very careful when tightening the brass fitting on the fuel line. Be sure to use two wrenches...
