I recently had the hot water tank replaced. The cold water pipe runs horizontally along the ceiling to the generally location of the hot water tank. The new tank was placed close to, but not exactly, where the old tank was. The drops are no longer truly vertical.
There is a 24" copper drop from the ceiling that, at the bottom end, has been pulled over 2.5" horizontally from where it would be if it were truly vertical. This is joined to a horizontal copper run (along which there is also a shutoff valve) over the top of the tank. The other end of the copper run joins to the copper pipe that comes up from the inlet at the bottom of the tank. The pipe that runs down the side of the tank is 64" long and the top end has also been pulled over 1" from where it would have been if it had been truly vertical (i.e. parallel to the side of the tank). In other words, the two vertical sections were forced closer together so that they could be joined to a horizontal section of pipe that was 3.5" too short. The result is that the vertical drops aren't vertical anymore. Is this acceptable practice? Should it be corrected? I suppose that this results in extra strain on the soldered joints. Does this place too much strain on the soldered joints? May this result in a leak sometime down the line (no pun intended).
