landscaping well pump
I contrived a diagram for a well pump. I take it the pump is some distance from the house but the storage tank, breaker panelbox, and pressure switch is on the tank and in the basement or "pump house." 12/2 romex should do the trick - tape the white wire black on both ends as the pump probably is 240 volt. The two pole breaker will feed both the pump and the timer motor. T1 & T2 is the motor load out from the timer. the contacts and jumper circuitry is internal to the timer. The timer will have a manual on-off lever if you wanted to bypass the on-off tripper fingers. I used Paragon as an example, Singer, Leviton, Emerson all make timers.
