2" is the correct size for the shower drain however the sink drain line would depend upon which code you are under.
Under the IRC (International Residential Code) a kitchen sink requires an 1-1/2" drain line.
Under the UPC (Uniform Plumbing Code) a kitchen sink waste arm (the section extending out of the wall) should be 1-1/2" but all concealed piping in the wall must be 2".
What's the best way to figure out if I should keep running a dehumidifier in my basement versus taking the plunge and having the basement waterproofe...
