fiberglass problem
  • dirtywork
    • Aug 2008
    fiberglass problem
    I'm not sure; but I think I used some Fiberglass resin that had been frozen. It was darker than usual & now it won't completely harden. Any Ideas? Thanks
    Did you mix the correct amount of the catalyst hardiner in the resin before use?
      fiberglass resins have a definite shelf life. there should be a date stamped or printed on the can. the tubed epoxies in a hardware store have "use by" dates on them.
      • jackmcmanus21
        • Aug 2008
        • 9
        I've used bad fiberglass resin before
        Do It Yourself
        water restoration
        • Frat-man-du
          • Aug 2008
          • 14
          I was working on a 67 'vette ( many moons ago) and didn't use enough hardener and after a week it still didn't harden and had to remove all the fiberglass I had laid - what a mess. Never did that again.
            acetone and lacquer thinner will dissolve the resin that hasn't hardened. companies make a co-polymer hardener that reacts with the base resin. methyl ethyl ketone [MEK] is part of the catylist that is used for the hardener.
