toilet flapper problem
  • ub1chris
    • Jan 2009
    My toilet was running continuously so I replaced the flapper and it doesn't leak anymore....however, now after I flush, the flapper doesn't fall back down and water just runs right through.
    Any ideas or suggestions?
    Chris.
  • thedcdude
    • Jan 2006
    • 82
    Is the flapper hanging up or rubbing on anything? If so try to reposition it see it operates freely. If this isn't the case, I'd try buying a different type of flapper. Some are of better quality than others.
      Check the alignment of the flapper it may be too high or too low on the refill pipe.
      • jnaas2
        • Feb 2008
        • 213
        If its the style that slips over the two holders on the overflow tube take a drill bit or knife and open the holes a little bit so it swings freely. If its the style that has a rod attached to it you need to find out whats causing it to bind up and stick.
