Toilet tank won't refill
  • Irwilliams
    • Jul 2022
    • 17
    I am having issues with my toilet tank. All of a sudden my toilet tank won't refill. I can pour water into it and flush the toilet but it won't refill by itself. What could be the problem?
  • handyandy
    • Sep 2002
    • 210
    Are you sure the water to it is turned on? Make sure you turn the water valve to the right. Let us know and welcome to the forum!
    • John Parker
      • May 2022
      • 16
      Probably a bad fill valve. A new Fluidmaster would cure that pretty easily. When you start to replace the fill valve, aim the supply line into a can or bowl and crack open the shut-of valve. Make sure you are getting water through that valve into the fill valve.
      Check this article to konw the common reasons for why toilet tank won't refill- https://toiletty.com/
