Tidy DIY Solutions for Hiding Network Cables
  • Gardenboy
    • 334
    Hey everyone, looking for some DIY-friendly ways to run internet cables along indoor walls. What are some neat solutions to hide the wires without making a mess or doing any major drilling?
  • machinist
    Moderator
    • 386
    Hi! One of the easiest and cleanest ways to run internet cables along indoor walls is by using adhesive cable raceways. They’re simple to install, don’t require any drilling, and can be painted to match the wall so they blend in better. For areas along baseboards or corners, small cable clips can help guide the wire neatly without being too noticeable. Planning the route in advance helps avoid adjustments later. In some cases, it’s also possible to tuck the cable under carpet edges, along door trims, or behind furniture to keep things out of sight without making a mess.
    • Gardenboy
      • 334
      Do adhesive cable raceways or covers tend to damage wall surfaces when removed?
      • machinist
        Moderator
        • 386
        Most adhesive cable raceways are made to come off, but they can sometimes damage the wall, especially if the paint is old or the surface is delicate. On smooth and newer painted walls, they usually peel off without much trouble if you go slowly.
        To make it easier, you can warm the sticky part with a hair dryer before removing it. Some types also use special adhesive strips that are easier on the wall and don’t leave marks.
        • Gardenboy
          • 334
          Thank you, Machinist! Also, are there any particular brands or types of raceways that are known to come off cleanly?
          • machinist
            Moderator
            • 386
            You're welcome! For raceways that come off cleanly, it's best to look for ones that use removable adhesive strips. Some are specifically designed not to damage paint or drywall when removed, which makes them a good choice for rentals or temporary setups.
            There are several well-reviewed options available online and at hardware stores. It's a good idea to check product descriptions and reviews to see how easily they come off. Look for phrases like "damage-free removal" or "removable adhesive" on the packaging.
            If appearance matters, some raceways are paintable or come in different colors to better match your walls or trim.
            • Gardenboy
              • 334
              Thanks again. Just one last thing, do these types of raceways still stick well if the wall has a light texture?
              • machinist
                Moderator
                • 386
                You're welcome! And yes, most of those adhesive raceways do stick just fine to lightly textured walls, especially if it’s just a subtle texture like orange peel. Just make sure the surface is clean. If the texture is a bit more pronounced, they might not grip as well long term, but you can always reinforce them with a stronger adhesive or small screws if needed and if that's an option. Some brands do better than others, so it’s worth checking reviews before buying.
                • Gardenboy
                  • 334
                  Thanks again for all the tips, really appreciate it!
                  • Alphalive
                    • Apr 2026
                    I’ve tucked cables into paintable adhesive raceways; they blend in once you hit them with the same wall color. Corner cable channels also work great if you want something low‑effort and no-drill. I once ran a long Ethernet line I got through and it stayed flexible enough to route behind baseboards without fuss. It all ends up looking pretty clean with a bit of patience.
                    • handyandy
                      • Sep 2002
                      • 210
                      I also find that you can push smaller cables underneath the baseboards. In the past few years there has been a lot of innovation in cable design. There are flat cables, skinny cables and a lot of solutions that was not available a while ago.
                      Check out Monoprice's "SlimRun" cables as well as their "Flat Flexboot" cables if you are looking to get a cable underneath a baseboard or hidden.
                      Originally posted by Alphalive
                      I stick flat cable raceways along the wall and paint them to match. In tight spots, I tuck the cable under baseboards using a plastic putty knife so I don’t damage anything.
