It sounds like you're dealing with a significant issue, especially with the crack in the ceiling growing over time. Given that your house is from 1969, there are a few possibilities to consider:
- Settlement or Foundation Issues: Older homes can experience settling as the foundation adjusts over time. If the crack is growing, it might indicate a more serious issue with the foundation or framing of the house. This is something a structural engineer should evaluate.
- Drywall or Plaster Problems: If your home has drywall or plaster, cracks can appear due to the natural settling of the house, but a growing crack might suggest more than just surface issues.
- Moisture Damage: Sometimes, water damage from leaks in the roof or plumbing can cause cracks to develop and expand. Check for any signs of water stains or dampness around the crack.
- Temperature and Humidity Changes: Changes in temperature and humidity can cause materials to expand and contract, which might contribute to the crack's growth.
Given the crack’s growth and width, it would be wise to consult with a structural engineer or a professional contractor who can assess the situation in person. They can determine if there’s a significant structural problem or if it’s a more manageable issue. In the meantime, try to monitor any additional changes or new cracks and document them to share with the professional.
