Insulation: joists are 14 1/2" on center, Insulation is 16"
  • vdotmatrix
    • Feb 2004
    • 314
    So myhouse was built in 1956. I guess they did stuff differently way back before electricity. I just tore out the drywall and old heavy insulation from the ceiling inthe garage which is also the floor of the upstairs room. The joist are 14 1/2" on center. Insulation I think is 16" wide. will it matter if I bunch up the extra 1.5 " in the joist. .
    shouldn't just try to keep it fluffy. when you build a wall and measure for studs, 16 on center, that figure of 14.5 always comes to mind.
      NO it will make little difference bunching it up. That's not such an uncommon issue, I find it a lot especially in late 1800 - early 1900's homes where the joists are 12" on center then it's a better option to cut the rolls bit at 14 1/2" centers your good to go.
