Enlarging Drywall Cutout
  • DD716TED
    • Nov 2004
    • 219
    I currently have a cutout in a wall that houses a TV. The cutout is only the thickness of the wall and the TV sits on a shelf behind the wall. Now I have purchased a larger TV and have to widen the cutout. I can do all of the carpenter actions but have a question concerning the drywall replacement. It appears as though I will have to blend the new drywall in the cutout recess to match the existing textured drywall pn the face of the wall. QUESTION.. Do I have to sand the textured area of the existing wall before I tape the corner joint between it and the new drywall in the recess or can I tape over the texture?
  • Drywall DIY Guy
    • Jan 2005
    • 108
    If I am reading this right, you will be enlarging the hole and then redrywalling and finishing. On an outside corner, I would use the metal corner bead rather than tape or tape on a corner. You will need a smooth surface about 8-10 inches in from the hole in order to have a nice smooth surface to draw your taping knife over. Then you will have to match the existing texture.
    How to tape and finish dryall. Tutorials and videos for taping joints and drywall repair.
    http://drywallinfo.com
