I am insalling a new acrylic tub and plan to tile instead of using the optional enclosure.I'm worried that the lip on the acrylic tub is so thick (about 1/4 inch x 1 inch high) that the tile backer board will be pushed out at the bottom creating a curve in the board which will be obvious when the tile is cut to fit.If I use 1/2 inch backing,there will be excessive space behind th tile.What to Do?
New tub installation
Tags: None
are you talking using cement board as a backer? an idea to do is use a masonary blade on a circular saw and make a 1/4 inch rabbett cut on the edge of the cement board so it fits over the lip. just keep making multiple passes until you can break it smooth. -
Thanks.My main concern was how or what do I use to stick the tile to the tub itself.I was planning to use a 6x6 tile.Will the mounted surface area on the backer board be enough to let the tile float over the lip without adhesive? Do I use thinset or mastic?Comment
