I recently noticed that there is moisture behind my vapour barrier at the lake. The house is 3 years old, 2 X 6 construction with stucco exterior. Beneath the stucco is housewrap. I see the moisture in several areas and looks like the start of small mold staining. Any suggestions on remedying the situation would be appreciated.
Moisture behind vapour barrier
The vapor barrier is where it should be. Inside wall side, behind the drywall. I am seeing condensation on the vapor barrier.Comment
stucco
a stucco is basically portland cement and sand. it is porous and allows moisture to leach through - it is not completely waterproof. high humidity is moisture in the air. you see condensation because of a difference of humidities and temperatures. you need to keep one or the other at a relatively constant temperature OR humidity to prevent condensation.Comment
