go to home depot or lowes and get a gallon of blacktop sealer. this comes with a narrow spout. cut the tip and pour [squeeze] out the product into your crack. this should seal your gap. the product remains flexible enough to make up for the summer temperatures and some winter temps.
Blacktop sealer is too thin and just runs down the hole. I'm not sure of how deep it goes but if I had to say probally 4-6 inches. What about using silicone caulk?
If your really worried about the crack you could always use that spay foam to fill the base of the crack then use the tubes of either concrete mortar repair or asphalt repair to fill the remainder. If you do use the foam option first them make sure you use the "Window and Door" product, it has much less expansion.
Hello all. I'm in the midst of planning a much-needed makeover for my home's interior, and I could really use some expert advice and creative ideas. My...
