gap between driveway and foundation
  • curious homeowner
    • Jun 2007
    • 7
    I have about a 1/8 in gap between the driveway blacktop and the concrete foundation. What would you suggest to seal this with.
    Thank you
    Curious homeowner
    go to home depot or lowes and get a gallon of blacktop sealer. this comes with a narrow spout. cut the tip and pour [squeeze] out the product into your crack. this should seal your gap. the product remains flexible enough to make up for the summer temperatures and some winter temps.
    • wvguy
      Painting, Decks and Fences Moderator
      • Apr 2007
      • 72
      concrete
      so do they have that in the same size for concrete also hayzee?
        the stuff comes in a squeeze gallon container. it is a flexible black compound and is pourable.
        • curious homeowner
          • Jun 2007
          • 7
          Blacktop sealer is too thin and just runs down the hole. I'm not sure of how deep it goes but if I had to say probally 4-6 inches. What about using silicone caulk?
            silicone would probably work. it's thick enough to stay where you put it if it only adheres to both sides of the crack.
              If your really worried about the crack you could always use that spay foam to fill the base of the crack then use the tubes of either concrete mortar repair or asphalt repair to fill the remainder. If you do use the foam option first them make sure you use the "Window and Door" product, it has much less expansion.
              • curious homeowner
                • Jun 2007
                • 7
                Good idea, now I have to go to work on it.
                • skootch
                  • Jul 2007
                  • 8
                  Urethane caulk
                  Home depot, lowes. Urethane caulk. Stick it down in the crack. It is thick enough to not run down. 50 year gurantee, I think.
                  • Rick Hurst
                    • Sep 2007
                    • 4
                    Crack
                    That crack is intended probably as a expansion joint and should not be filled permanently.
                    You could fill in with "play ground" sand for cosmetic appearance and it still function as a expansion joint if needed.
                    rick
