Hi,
I have a couple problems. The first is my wiring job (which caused the second problem).
I've got a hot line coming into a junction box and a switch for a simple light fixture (this is all in the attic) above and another line running to a receptacle for the AC below. I ran all whites together, all blacks together and all grounds together (which I now know was wrong). When I restored power to the circuit, the light was on even though the switch was in the "off" position and the thermostat for the AC was on, displaying its temperature. I'm sure it's something involving the switch (for some reason I have a problem with those) but when flipped to the "on" position, the light went out. Now it won't turn on in either position...
Which I believe is due to the second problem. In the breaker box, this circuit has been blown so I went to make sure it was off so I could try and re-wire but the switch is now basically flopping back and forth with no satisfying "thunk" when in either position. Using the voltage detector, I can see that power is still running (which worries me, frankly.)
I guess the first step is the breaker box, then back into the attic. But what can I do to achieve my mission on both fronts?
Many thanks
Many thanks
If it is tripped, how do you reset it? It's just flopping back and forth at the moment.
