jack posts
  • Ishmaelette
    • May 2004
    jack posts
    Can anyone tell me where I can buy jack posts (and what I can expect to spend)? Thanks.
  • handyandy
    • Sep 2002
    • 210
    What are jack posts?
    • Kevcules
      • 18
      I believe you are talking about steel support posts which you sometimes need for a basement to support the upper floor load. I bought a couple of 36 inch ones, and they cost $20 each. You can find these at any harware store.
        If i understand the question correctly, what you are calling jack posts are commonly called lolly columns in the trades. Commonly they are in two sections with a pin that is put in to make the coarse fit, then they have a screw at the top to work as a house jack to make the final fit.
        They are available at most lumber companies, large hardware stores or the major home improvement stores.
