How do I cut quarter rounds for corners?
  • showson1
    • Sep 2004
    Hi all!
    I've been helping my buddy put in laminate flooring over the past few weekends.
    We got the whole thing in and we're working on putting 1/4 rounds around his fireplace right now.
    How the heck do I cut it to make an outward corner around the fireplace?
    Is this even possible because of the shape?
    A corner going in (such as the corner of a wall) I can figure out, just can't figure out how to go the other way.
    Thanks!
  • geniere
    • Sep 2004
    • 8
    If your corners are square, the piece you throw away after cutting your "inward corner" is the one you use for your "outward corner".
    • showson1
      • Sep 2004
      But how do I get a good seam with the rounded edge? How do I get them to meet flush?
        In a perfect world the corner should be a true 90 degrees so you would cut a 45 degree miter on the end of each mating piece.
        It the real world things are seldom a true 90 degree corner. You can get an angle finder that will measure the exact angle of the corner, then each miter is exactly 1/2 of the angle.
        In order to cut moldings that finite one needs an adjustable miter box or a powered miter saw.
        The second option it to cut the 45 degree angles with a simple miter box, Use a sandpaper block to fit the pieces as best you can and fill the gap with wood filler or caulking.
        • rockyjp
          Banned
          • Apr 2008
          • 21
          Cut the end of 2pcs of quarter round with 45 degree and 135 degree separately. Then the ends of the 2pcs of quarter round can be put together well at the corner. The gap for laminate flooring can't be too big or too big.
