sub floor for tile?
    sub floor for tile?
    I am planning to lay ceramic tile on a bathroom floor that is 5' x 12'.
    This is in an old house that currently has 3/4 oak flooring directly on the floor joists with no subfloor.
    I need to keep the overall buildup as low as possible, so what is the minimum thichness of plywood subfloor and tile backerboard I can go with?
    • 8747
    I would go with 5/8 OSB or 5/8 particle board made for making counter tops
    • Terry Cousins
      • Jun 2005
      • 12
      You don’t say if the ¾" oak flooring is T & G or not, but if it is, and doesn’t have any noticeable high spots or hollows you should be able to over-deck it with #8539;" ply providing it is fixed off at regular 4" intervals.
      Hope this helps - Terry
      Now you can work with the confidence of an expert – without having to put in the years of practice!
      www.easycarpentry.com
