Hello,
I have a lennox gas furnace like in the title. For some reason (probalby bad contacts) one of the relays has burnt so badly that it has destroyed part of the printed circuit board. I have bought new relays but now i have a small problem with the circuits. Because of the burnt board about 2cm square have been destroyed and i want to fix it somehow. My tehnician wants me to buy a new board - that's about 500$. The two relays have cost me 2$. Equation is easy- i wanna fix the board
. With this control unit burnt as it is the furnace works except for the main fan. The furnace starts normally, fumes ventilator, burner and after some time the main fan should start but it doesn't so the whole furnace shuts down after a while because of too high temperature.
I looked through the internet and i can't find anywhere either the electrical diagram of the board or the picture of it.
My question is - does anyone has got a picture of the same board i have, or the diagram so i could fix it. I enclose the pictures of my control unit
and a picture of the burnt place
and a close up
can anyone help me with this? how to connect it? if someone has the same board I would really appreciate if I could have a picture of it
hmmm can't add urls to outside sites.
. With this control unit burnt as it is the furnace works except for the main fan. The furnace starts normally, fumes ventilator, burner and after some time the main fan should start but it doesn't so the whole furnace shuts down after a while because of too high temperature. I looked through the internet and i can't find anywhere either the electrical diagram of the board or the picture of it.
My question is - does anyone has got a picture of the same board i have, or the diagram so i could fix it. I enclose the pictures of my control unitand a picture of the burnt place
and a close up
