I have a COLEMAN / EVCON Model ; BGM05012AXD The problem when I turn on the heater after 2 minutes its turning on off every second, the gas turns on for a sec then off , after a couple of minutes its just clicking none-stop ,the fan is working thermostat is fine (I tested) the furnace clean. This unit is about 10-15 years old .
COLEMAN / EVCON Gas Heater
I am guessing you have a flame rod around the area of the pilot assembly. You have a sparker that makes that clicking sound. First off you have to make sure the pilot is clean and burning a good blue flame. This flame cannot lift off the pilot burner head, and it has to burn across the sparker to a ground plain. If it does not make contact like this. it will not turn the sparker off and it will not prove pilot flame, and act the way yours is. Clean all metal surfaces with fine sand paper, including sparker and ground plain. . PaulI have a COLEMAN / EVCON Model ; BGM05012AXD The problem when I turn on the heater after 2 minutes its turning on off every second, the gas turns on for a sec then off , after a couple of minutes its just clicking none-stop ,the fan is working thermostat is fine (I tested) the furnace clean. This unit is about 10-15 years old .
Channel: Toyo Heaters
