Brand:Carrier
Model: 38CKC030-341
Well as of yesterday my 6 Year Old AC Unit that is located in the backyard stopped working, after many troubleshooting by me a COMPLETE NEWBIE to AC repair, I found out:
I tried the Circuit Breakers, ON OFF, still did not function
I Tried different Settings in Thermostat, still did not function
Unit HMMMMS, but Fan does not spin, after about 5 mins of Humming, it turns off, some air enters the house during this.
I opened the AC panel and the Capacitor looks fine, No Bulging, No leaking.
The Contactor works fine also, Nt burned, Not Stuck.
I finally decided to give the fan a push with a stick during the Humm, and to my surprise, it worked fine, until it reached the level of coolness programmed and then shut off, then when it got warm again the unit turned on outside, but again with no fan.
I don't know what to try next?
I don't have anything to test the capacitor, can I still take it out and test it with a screw driver? I read somewhere if there is a spark, it still works? If not then its dead. Is this ok/safe?
I only see 1 capacitor, is there 2? I believe I have a Dual Run Capacitor on the unit, but again I only see one.
The Fan is not stuck and doesn't seem to wooble, although I have not took it out to fully test. I also read that I can add oil to it, should I do this?
Thoughts please.
Thanks in advance, GREAT SITE, glad I found it
57413k
Model: 38CKC030-341
Thoughts please.
57413k
