sears coldspot freezer
  • erikk71
    • Jul 2011
    Here recenly i discovered a rat had eat the white going to compressor relay.
    The white wire is coming from the junction box where the power cord is attacthed
    I am stilling having some trouble figuring out where the all the wires go
    a friend help me but made a mess.
    Funny thing we did not see a wire attached to common
    the model 1067637260
    the white is a neutral. the capacitor's wires are brown and brown with a white tracer. the black goes to the hot line. green is earth ground.
    • erikk71
      • Jul 2011
      sears cold spot
      I recently purchased supco powerstart relay overload ROC810
      The freezer is trying to cool but only gers to about 50 degrees
      I believe the hp on the compressor is 1/2 hp
      Orig the white coming from junction box broke
      As you there is two wires a red an white
      The relay broke trying to put news on there trying to plug on new wires
      I have heard a relay will cost 50 bucks the compressor needs start capacitor on it
      Before i spend that ill change the compress an i have do have r12
      any suggestions would be appreciated
      • erikk71
        • Jul 2011
        sears coldspot
        Can i get a relay an overload that will allow me to hook the start capacitor to it.
        The compressor needs the start capacitor
