heating problem.
  • brucemoore
    • Mar 2004
    • 5
    heating problem.
    I have Comfortmaker gaspack installed 1990.
    When the heat is trying to come on, I can see it in the thermostat (blinking temperature). However the heat and blower are not on.
    To get working I move the heat/off/air switch to off then back to heat. The thermostat is a setback type and I have changed the batteries.
    Ant ideas what needs to be done?
    visit my website:
    password: time&money
  • Hube
    • Nov 2003
    • 453
    Welcome to the forum. First, how do you know the "heat is trying to come on"? A "blinking thermostat can indicate that a signal has been sent to the gas valve and could energize it to open in a few seconds. When you see this "blink", how long after does it take for the burner to lite, or does it without you flipping the switch? Hube
    • brucemoore
      • Mar 2004
      • 5
      The blinking occurs indicating that the gas pack is going to ingnite the pilot, start the blower and clear the ducts, then light the burners. I can hear the unit but the blower does not start. All I have to do to get everything to work is move the heat/off/air switch to off then back to heat. What happens different when I switch the heat/off/air switch to off then back to heat?
      visit my website:
      • Hube
        • Nov 2003
        • 453
        Make sure the terminals on the T- stat and the furnace gas valve (relay) are clean and tight. Hube
