Outdoor Kerosene Fuel Tank Cleaning
  • bbraden01
    • Apr 2012
    • 24
    Hi, I have a 275 gallon exterior kersosene fuel tank. I recently rebuilt my Monitor 2400 heater and I was wondering if there was anything I should/could do to clean the fuel tank? I just replaced the fuel filter, but before I return the fuel flow I was wondering if there was a way to check for water or excess sludge in the tank? There is no valve on the bottom of the tank for easy checking and I know the water goes to the bottom. I was thinking of using a piece of tubing attached to a boat fuel primer to create a gravity fed suction tube to check for water on the bottom of the tank...thought or suggestions? The tank is full at the moment too.
    Brandon
    fuel tank
    the amount of fuel really doesnt matter kero will float on water. a long piece of poly pipe that reaches the bottom through the bung hole connected to a bilge pump will suck water out of the tank. Put it into a glass jar so if there is any water the kero will filter out and float to the top. they make a paste that you could put at the end of a dipstick, if water present it will turn a pink color.
    • bbraden01
      • Apr 2012
      • 24
      Thanks Hayzee!
