Connected.......
36k BTU Propane Fire Logs- Connection Help
fire logs
the output from the propane tank is reverse threaded for a reason. the pressure coming out of the tank is HIGH pressure. most regulators have a high pressure malleable copper line of very small diameter [1/4" or smaller] on the inlet side and a standard 3/8" flare fitting on the outlet. never use compression fittings on a propane or natural gas line. always use flared fittings or black pipe.
Channel: Toyo Heaters
