Furnace
  • gbialas
    • Jun 2004
    Furnace
    I have water leaking from my furnace when i turn on the air conditioning. I did notice i have a pump attached to the furnace which has a hose go from the furnace to this pump then out to a water line. There is no water in this pump however. Any ideas whould help.
  • Hube
    • Nov 2003
    • 453
    Hi, and welcome to the forum. What you probably have is a condensate pump that is supposed to remove any (condensation) water that the a/c coil will send it. There could be a build-up of crud, debris at the coils drain pan where it drains into this tube line and into the pump. Clean out the pan, tubing,etc, and this should solve the problem.Good luck Hube
    • imeduc
      • Apr 2004
      • 330
      You can try and just blow back in that hose from the coil to the pump. A shop vac work good for this. Also check and see if the air filter is clean.
      ED
