Radiant Closed System ?
  • Bill Bresnan
    • Nov 2004
    Hi all -
    Hope everyone had a great Thanksgiving !
    Question of the day...... Can I install a "closed system" with it's own small water heater for a small space ? Hooking up to exisitng system may be a problem - so I was wondering if it can be done. It would be installed under a wood floor in the joists - and can place a small electric water heater close to it. Please give me some advice !
    Thanks !
    Bill
    There should be no problem with doing it that way, however, the water heater you select has to be listed as a heating boiler/water heater.
    Water heaters that also serve as heating boilers are quite common and you should have no problem finding one listed for this application.
    • imeduc
      • 330
      Why not BIG BIG are just small. It all works if put in right
      ED
      • Bill Bresnan
        • Nov 2004
        THANKS, LAZYPUP !
        Any suggestions on a BRAND & where to find one ?
        Thanks !
        Bill
          My personal choice of water heaters is A.O.Smith or Rheem, but they are all pretty much the same.
          • Bill Bresnan
            • Nov 2004
            Thanks AGAIN Lazypup !!!
            I went to the Rheem website. Does this look like what you were telling me about ? It is their FURY MODEL ? SEE BELOW.
            THANKS !!!! BILL
            Fury
            Energy Miser Electric Water Heater
            Available in 30, 40, 50, 65, 80 and 120 Gallon Tall - 30 and 50 Gallon Medium - 20, 30, 40, 47 and 50 Gallon Short Models
            6-Year Limited Tank and Parts Warranty, 10-year Limited Tank and 6-year Limited Parts Warranty with Protection Plus.
            Brass drain valve
            Anode rod equalizes aggressive water action
            Automatic thermostat keeps water at desired temperature
            Electric junction box located above heating elements for easy installation
            Energy Factor and Average Annual Operating Costs based on D.O.E. (Department of Energy) test procedures. D.O.E. national average fuel rate electricity 8.41¢/KWH.
            High efficiency resistored heating elements
            Isolated tank design reduces conductive heat loss
            Meets California Energy Commission standards for new residential construction (Title 24, Section 2-5352(I)
            Meets or exceeds National Appliance Energy Conservation Act (NAECA) requirements
            Over-temperature protector automatically cuts off power in excess temperature situations
            Temperature and pressure relief valve included
            High Efficiency Models: High performance and recovery
            High Efficiency Models: R-Foam® insulation process with approx. R-value of R-20
            High Efficiency Models: Compliant with many electric utility incentive programs
              That water heater seems to have very good specs, however, shopping for the water heater at this time is sort of putting the cart before the horse.
              You would need to determine the BTU requirements for the space you intend to heat, then select a water heater that is also listed as a hydronic boiler with a BTU rating equal to or slightly greater than your demand. In essence they are the same as a common water heater but they also have a BTU rating for use as a hydronic boiler.
              Many common water heaters do have the hydronic specs but you have to ask the MFG or dealer for the spec sheet for the hydronic application.
