Symptoms: The Digital Thermostat reaches desired temp. blower shuts off, however the heat element stays on.
I can tell it's on, because the sheetmetal is still warm after the blower has been off for quite some time.
It is just a Coleman Presidental, the trailer was built in the 70's. I am thinking somthing mechanical has failed, I suspect the relay that turns the heater element on/off is sticking or malfuntioning?
I don't think it is a thermostat issue, since the blower shuts off, the heating element should shut off also.
I have not peeked inside, so I am not sure how it is wired.
