I've been trying to stop my Florida Heat Pump geothermal furnace from making this very high pitched sound while it is running. It sounds like a kids top that is spinning very fast. I've had the furnace repairman out 3 times & so far he has had no success in stopping the furnace noise. The furnace is model GOO48-1VTC. I've written FHP for suggestions & they replied with it might be the TXV valve or the HRP pump or maybe a loose heat strip. The repairman says that everything is OK, but he can hear the noise also. I've been here for 4 years & it just started making this noise this past winter. I think the furnace is about 14 years old. My furnace is on a loop system & is also connected to the water heater. Your help is really appreciated.
Thank you,
Fred
Thank you,
Fred
