Need Some Heat
  • Need Some Heat
    I Have A Central Air Unit (date & Model# Unknown) It Was Working Fine Frm 2/07-10/07 All Through The Summer However When We Went To Turn On The Heat Cool Air Blows Out The Filters Have Been Please Help!!!!!!
    is it gas or electric???? is pilot lit??
    Is it beer thirty??
      This Is An Electric Unit. It Cuts On But Still Blows Cold Air
        so can you hear the relay pulling in?? can you check with a volt meter?? maybe a bad safety (thermal disk)??
        Is it beer thirty??
          Yes I Can Hear It Pulling In, How Do I Check The Volt Meter?
            Do you have a volt -ohm-milliameter? If you do set the selector on AC volts and the range on its highest scale. If you know where the contactor is measure the voltage on the line side and on the load side. The voltages should be equal. Let us know what you find. I'll be on the computer off and on all day.
