problems with gas furnace
  • samnc
    • Jan 2008
    I have a gas furnace about 12 years old. Yesterday,it did not cut on when it was supposed to. I turned the temperature on the thermostat up, nothing happened. I then switched the thermostat from "auto" to "on" and it blew cool air. The unit made the same kinds of sounds it does when it worked, but it didnt have a red glow inside of it.
    I have a repair man coming today. Someone told me it sounds like the thermocouple, which means it is a cheap and easy fix. Does it sound like it is this? Is there anything else is could be?
    Out of all the nights for it to konk out, it chose to do this on the coldest night of the year!
  • Java_Bob
    • Sep 2006
    • 168
    if it is a standing pilot did you try and relight??
    Is it beer thirty??
    • hvacwiz
      • Apr 2006
      • 97
      My guess is the igniter is out.
        Laser 730 over firing
        by hawkins111
        Has anyone had an occurrence of a Laser 730 or 731 over firing?
        The top of the heat chamber and the heat exchanger glow red on high when this occurs....
        11-12-2024, 10:29 AM
      • 911Restoration
        Fireplace Woes
        by 911Restoration
        09-22-2026, 03:14 PM
