Furnace won't cycle
  • deck52
    • Jan 2009
    Furnace won't cycle
    I'll have to describe a switch (because I don't know what this switch is called) before I describe the problem. There is a conduit box on the wall next to the furnace. There is flexible conduit going from this box to the furnace. On the conduit box cover is a switch, and on top of the conduit box is what looks like a transformer. Attached to the transformer are the wires that go to the thermostat upstairs.
    Here's the problem: sometimes the furnace won't come on even though the room temperature is well below the thermostat setting. If I turn the switch described above off then back on again, the furnace kicks in immediately. Sometimes I can go for weeks without the furnace doing this, and sometimes I have to turn the switch off and on several times a day. I have replaced the thermostat more than once, and replaced this switch once too. The problem persists. Help!
    turning the power of then on is resetting the internal computer. trouble shooting it to find out why its cutting out is another story.
