i have a carrier furnace...there is water leaking out the bottom ,itook off the panel and hear a gurgling sound while the furnace is running...i dont see any water coming out the condinsate tube....but i see water around the heat box...behind the fan..could a hose be split behind the fan...or is there a simple fix..before i have to remove the fan...i turned off the water supply to my humidifier, so i know its not coming from there...
furnace
Channel: Toyo Heaters
