Fans for Fireplace
  • krm944
    • Dec 2006
    • 7
    Fans for Fireplace
    I have a fireplace with two small fans under the firebox that blow heat out of the top.
    My problem is that the two small fans do not have enough air movement.
    What options are available?
    I considered replacing the fans with a squirrel cage and motor.....room is tight.
    Any ideas?
    Kyle
  • Java_Bob
    • Sep 2006
    • 168
    They really do not put out much, mine are the same way basically useless....
    Is it beer thirty??
      if you want a cheap fan just to try go to allelectronics dot com. look in the left hand column for FANS. I think last time I looked there's four pages of fans. most are low voltage, but any cheep power supply from radio shack will do, they have small squirrel cage fans that work really good! I got one in a cold air line that cools off my beer tower ten feet away from the kegerator.
      KRM where in clinton county? my wife is from keeseville.
      • krm944
        • Dec 2006
        • 7
        I grew up and have a home in Ellenburg..............waaaay up north.
