Attic Fan!!! SOS!!!!
  • Price1975
    • Jul 2010
    Can anyone tell me what I need to do to repair an attic fan??? My future wife and I moved into my grandmothers old home recently and the attic fan had been painted shut.....The motor and all seems to be working just fine BUT I believe the paint has weighted down the flaps and I dont believe the fan has enough power to get the flaps open Is there a way I can fix this problem??? Any ideas would be greatly appreciated!!! Thanks for reading!
    Have a blessed day!
    use a brush on paint and varnish remover, liquid or gel type. once the damper is freed up, neutralize the remover with alcohol. when dry use a good thin oil to lube the pivot points.
    • Price1975
      • Jul 2010
      Will it not eat up the canvas when I try to...
      Remove the paint???
        canvas?? aren't the shutters made of metal?
        • Price1975
          • Jul 2010
          No sir.....they are not. I wish I could post a pic!
          They are canvas...
            use a razorblade carefully between the slats and around the edges.
            • Price1975
              • Jul 2010
              Attempt......failed.....
              just cant generate enough power to get the flaps working...
                well, then, I guess the bottom line is either replace all the canvas flaps with new canvas or replace the gable fan with one of higher cfm's and a weighted damper louver.
