Hi, I have a dual zone HVAC system made by Goodman. The upstair handler is in the attic. I noticed that there are two drain lines side by side on one wall of the unit in the attic. One of the lines is plumbed to drain the condensate to the outside of the house. The other line is plumbed to drain directly into the emergency pan that the unit sits in. Of course, the emergency pan has a line that drains also to the outside of the house.
Since one of the drain lines from the unit drains directly into the emergency pan, this pan always has about 1/2 inch of water (since the drain line for the pan is raised up about this high.
Is the second drain line really suppose to drain into the emergency pan? Is there always supposed to be 1/2 of water in the emergency pan? Why did they not just run both drain lines to the outside world and leave the emergency pan for real emergencies? And why are there two drain lines on the unit, side by side?
Thank you very much for any insight.
Bluesky
Bluesky
