I have a squirrel Cage fan I am installing in my garage and I don't know if it is complete or how to wire it correctly for 110v AC operation.
there are 2 wires that come out of the motor, one is brown the other is blue, and both wires are connected to a 2 terminal capacitor, and there is a connection terminal on the motor with 3 spade connector positions, low med and high, but there are no external wires connected to it. i have no clue how to wire this. Any ideas?
Edit================================
ok...well last night I decided to find out exactly what i was dealing with. Here is what i found.
The Electric Motor is 208-230vAC 7.5 Amps There is no 110-125vAC operation spec on the motor.
That solves a huge problem.
Ok so i need to hook it up to my 220 outlet. I can do that, except...how the heck do I wire this thing?
I have taken the Experimental route and have come up with some results, but nothing im happy with. For instance, If I hook L1(120vac) to Yellow Terminal on Capacitor, and the Purple Line(Run circuit I believe) to the Yellow terminal on the capacitor, then the L2 (120vac) to the Unmarked terminal on the capacitor, the a Jumper lead from L2/Unmarked Terminal to the High speed position on the motor, I will run, but starts very slowly.
If I then hook the Brown Lead to the Common, The Motor will spin up fast, but will not accellerate to full RPM until i disconnect the brown lead from the common. Fan then Spins at high RPM and seems to operate correctly.
I know I don't have this right, It should just come on and run. hope this gives a clearer picture of what im trying to work with.
Thanks in advance.
