HIAC Furnace problem: Burners come on and stay on, Blower fan running,does not heat house, Burners and fan run contineously,blows luke-warm to cool air. Flame is blue, filter changed. Whats wrong
fURNACE PROBLEM
Tags: None
furnace problem
thank you for your response; Rheem Criterion,model #RGDG 125ARJR, (125,000 btu)supply is natural gas, with pilot.Comment
Sounds like you need to have the gas pressure checked, Does the hot air plenum
get hot? Do you have good air flow coming out of the reg.? Do you have any other gas equipment in the house that is not working right? When you look at the flame in the burners, how hi is the flame? Later PaulComment
Channel: HVAC
