I have a Monitor 41 that I "inherited" when I bought my house around 6 years ago. It has worked great up until now. When I turn on the heater, it goes through the start-up routine and then shuts off and all of the bars blink. I have spent most of the weekend going through most if not all of the posts here and have learned quite a lot. The combustion post does get hot and the fan works normally. I believe that I am not getting any fuel to the pot. I have an external lifter pump that works fine. I have plenty of fuel in the sump tank. I have taken it out and cleaned it as described in other posts. I have taken out the line between the solenoid pump and the pot and it appears to be clear. I can blow air through it. I believe that it has something to do with the solenoid pump. I have contacted my local distributor and was told that the solenoid pump is discontinued.
If it is the solenoid pump, any suggestions as to where to find one?
Is it possible that it is not the solenoid pump? If so, any suggestions as to what I should test next?
Thanks in advance for any help.
